Mondeo TDCI 04plate problem?
Old Dec 17, 2009 | 07:28 PM
BigTownz's Avatar
BigTownz
Default Mondeo TDCI 04plate problem?
Firstly can I say a big hello as im a newbe here and this is my first post. I never actually knew forums like this existed.
Anyway on to the problem. As the title says I have a Mondeo TDCI 04plate which I recently had a new dual-mass fly-wheel, starter motor, clutch and release bearing fitted to. The problem is it is now failing to start 1st time. If I come out in the morning it will start 1st time but throughout the day it can take up to 5 attempt to start. I have recently serviced it but never had new glow plugs fitted as I was told there is nothing wrong with them otherwise the light would be flashing and the car wouldn't start at all. Just to be clear the light isn't flashing. Also I have had the EGR off and cleaned it all but this has had no affect. I have had it hooked up to a diagnostic machine but no faults were found. What could the problem be?
Sorry for the lengthy reading
cheers
BT
Old Dec 20, 2009 | 11:14 AM
G Beale's Avatar
G Beale
Not exactly the same but I had one on an 03 plate that would cut out for no good reason. Turned out to be the cam sensor, Ł24 from Brooklyn, 5 minute job.
Old Dec 20, 2009 | 05:32 PM
saph4be's Avatar
saph4be
sounds like a crank sensor issue as it picks up off flywheel so maybe they caught it and damaged it some how
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
Brickhouse
Sep 20, 2015 11:47 AM
talon1
Sep 15, 2015 10:27 AM
marky_g
Sep 12, 2015 04:26 PM
