I've found a crack!!
Old Dec 16, 2009 | 06:55 PM
rstoughy's Avatar
rstoughy
Question I've found a crack!!
While cleaning up my bolck tonight for the imminent rebuild i noticed a hairline crack.
Now i know it's quite common for these blocks to crack around the long studs but just to be sure i thought id take a few pics and see what the engine builders on here thought
The engine was running great prior to removal from the previous owners car but has been sat now for a couple of years (hence the full strip down)
Now it's pretty hard to see so i have stuck a couple of pencil arrows towards it.
What do you recon???
Oh its a small turbo Escos block.
Old Dec 16, 2009 | 06:59 PM
saph4be's Avatar
saph4be
mine was same it normally normal head bolts that cause this so i belive and longstudding is a way round it would imagine it would be ok tbh
Old Dec 17, 2009 | 02:05 PM
rstoughy's Avatar
rstoughy
Any others
Old Dec 17, 2009 | 02:07 PM
rog's Avatar
rog
I don't know if I am more shocked at the crack, or the fact you've actually started rebuilding the engine at last..... Good luck with it mate, i know it'll be a proper machine when your done with it.
Old Dec 17, 2009 | 03:00 PM
AustenW's Avatar
AustenW
Try it, whats the worst that could happen?
Leaks water
Old Dec 17, 2009 | 04:24 PM
rstoughy's Avatar
rstoughy
LOL been working away in the background on it now for a couple of months Rog
Old Dec 17, 2009 | 04:27 PM
rstoughy's Avatar
rstoughy
Leaks water
Yeah i know and i doubt it will even do that but just really trying to confirm my suspicions that it's all ok.
Cossie paranoia and i aint even got the thing back on the road yet LOL
Old Dec 17, 2009 | 04:38 PM
adam151082's Avatar
adam151082
Is it def a crack? Not a scratch. I'd take the paint of at the side of the block with strippers (not abrasive's) and see how big it actually is. Good Luck either way.
Old Dec 17, 2009 | 04:48 PM
paul16v's Avatar
paul16v
Monte 087
As said is it deffo a crack, looks very straight they dont usually crack in a perfect straight line like that
Old Dec 17, 2009 | 04:54 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
as said, looks like a scratch more than a crack.
Old Dec 17, 2009 | 08:30 PM
markk's Avatar
markk
I would have it checked properly why waste your money rebuilding if the block is cracked?
Old Dec 17, 2009 | 10:38 PM
paul16v's Avatar
paul16v
Monte 087
See if you can get hold of some flaw detector spray, it comes in 3 aerosol tins a solvent cleaner a dye and a revealer, we used to use it on small fab work we did at work, will show it up clearly if it is a crack or not.
bobsworth
77
Mar 24, 2016 09:30 PM
2wdsaph ben
18
Oct 2, 2015 05:18 PM
muzzman1
Sep 30, 2015 08:59 PM
rsguy
44
Sep 29, 2015 03:29 PM
SMILER258
Sep 28, 2015 09:04 AM
