Brakes locking on
Old Dec 12, 2009 | 11:08 AM
Rune's Avatar
Rune
Default Brakes locking on
Hi
I've had a problem for a while now with the brakes locking on, the car is a 1998 1.8 gti escort and I've replaced the following parts to try solving this
New: brake calipers, servo pipe & vehicle speed sensor (speed sensor was definitely faulty as you could just pull the chip out of the top of it)
Used: servo & master brake cylinder
One thing I noticed when I picked up the servo and cylinder from a local breakers is, they took it off the car whilst I was there, and when the servo pipe was removed there was quite a lot of pressure, took a minute or two for it all to release/escape. You could hear it escaping from a few yards away
When you pull the pipe off on my car, both with the original servoand servo, and the ones from the breakers it takes 2 or 3 seconds for it all to release, and quietly
I'm not sure which of these behaviours when you pull off the pipe is the one to expect, but as mine is the one with the problem I kinda suspect it isn't building up the pressure it should
Am I correct on that?
If so, what likely causes are there for this that wouldn't be fixed by the parts I've already replaced?
The car never had this problem until the engine in it was changed, so I think it's at least possible that something hasn't been refitted properly when that was done, anyone have any ideas of possibilities there?
Also, after the engine was changed it was a case of the brakes were fine when you first started driving it, but the further you drove (and so the more the brakes got used), the more they'd stick on
Then after the clutch was subsequently changed they just locked on solid so the car struggles to move at all now
One for knowledgeable folks to chew on I daresay, I've been thinking of getting a local garage to run diagnostics on it but I'm not even sure whether diagnostics would be any use for this kind of problem
I'm getting to the point where I'm on the verge of just giving up on the car but I don't wanna do that if I can help it, it's apparently quite rare being the estate version of the gti with skirts, aircon etc, besides which I really like the car when it's running ok
Old Dec 12, 2009 | 11:32 AM
Fiesta SuperSport's Avatar
Fiesta SuperSport
Could try the front flexi hoses, this is a common problem on mk6 escorts they break down inside and dont let the fluid back properly.
When changing the engine you could have crushed one of the metal brake pipes in the engine bay which could cause the same problem maybe?
Hope it helps
Old Dec 12, 2009 | 11:49 AM
Rune's Avatar
Rune
Funnily enough mate I did buy a roll of brake pipe and the end bits because I had the same thought
Myself I'm fairly clueless when it comes to mechanics, it's a mate does all the fiddling with it for me and his reasoning was that the pipes are fine because the brakes bleed ok
It is only the front brakes affected, if that makes any difference
stephenb4506
33
Oct 2, 2015 06:25 PM
2wdsaph ben
18
Oct 2, 2015 05:18 PM
muzzman1
Sep 30, 2015 08:59 PM
rsguy
44
Sep 29, 2015 03:29 PM
