mfi cvh question
Old Nov 26, 2009 | 05:56 AM
dazzaj's Avatar
dazzaj
ps3 name.. LYNX-79
Default mfi cvh question
the engine is a xr3i 1.6 mfi. can i scrap the inlet injection manifold. and just put a 1.6 carburettor and inlet on instead?? will the carburettor manifold line up with mfi head?? will it run properly?? wanna throw engine into mk1 fiesta.. thanks....
Old Nov 26, 2009 | 06:10 AM
rickbartlett's Avatar
rickbartlett
G911 TTA
yep manifold will bolt strait on mate.emgine is the same as a carb fed mk 2 xr2 fiesta
Old Nov 26, 2009 | 11:52 AM
dazzaj's Avatar
dazzaj
ps3 name.. LYNX-79
cheers fella
Old Nov 26, 2009 | 09:28 PM
AstoN_B's Avatar
AstoN_B
An eye for detail...
just make sure fuel pump is right one for carb mate.
Old Nov 26, 2009 | 10:01 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
as said heads are the same on the casting for the inlet manifold ports anyhow.
lean burn/hemi heads are different, but make no odds for your modification.
you will need to use a fuel pressure reg for injection pump to carb though and override the fuel pump relay so it works with ignition instead of off ecu.
reg availible from burton power etc.
Old Mar 20, 2011 | 10:25 PM
gagzyboy's Avatar
gagzyboy
mk3's are the nutz
how will this effect performance??
mk3ste
Oct 17, 2021 10:09 AM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
stevecfrst1
Sep 30, 2015 05:18 AM
