amal valve
Old Nov 16, 2009 | 12:52 PM
matcossy's Avatar
matcossy
Default amal valve
hi all i need some advise on how to mod my amal valve?
many thanks to all
Old Nov 16, 2009 | 08:49 PM
cossiesimon's Avatar
cossiesimon
im just doing the same thing been told to slightly increse the hole size on my sapph amal valve to increase boost this will allow more air to blled off. said to do the one with R above it the return to the air box
Old Nov 17, 2009 | 06:45 AM
oldford's Avatar
oldford
Remove the white plastic restrictor from the R outlet completely.
That's assuming you have a valve with 2 outlets and 1 inlet.
Old Nov 17, 2009 | 04:09 PM
As said screw into hole then pull out the plastic plug/bung.
steve.rst
Mar 15, 2016 08:01 AM
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
rs_jim
Sep 19, 2015 08:41 PM
