2WD diff
Old Nov 15, 2009 | 10:16 PM
Alan Whitaker's Avatar
Alan Whitaker
Default 2WD diff
Hi All.
On the 2wd diff with the 108mm flanges which ratios were used and how do you tell the ratio without the diff tag.
Were these 2wd diffs lsd or not.
Many Thanks
Alan
Old Nov 18, 2009 | 04:55 PM
Lloyd's Avatar
Lloyd
escort mk4 cossy 4x4
3.6 ratio, not all are lsd.take the back plate off, and count the teeth on the crown wheel and the pinion
Old Nov 18, 2009 | 05:03 PM
nb just to add divide the crown wheel number by the pinion number.
Old Nov 19, 2009 | 05:07 AM
Alan Whitaker
Hi
Thanks guys, Should have thought of that.
Alan
Old Nov 19, 2009 | 07:01 AM
You can do it without taking the cover off as well, by marking the wheel and the prop, then turning prop until wheel turned complete turn count how many turns of the prop, if it comes out at just over 3 1/2 turns then it is a 3.62.
NB got to have both rear wheels in the air if lsd.
Old Nov 20, 2009 | 05:29 AM
Alan Whitaker
Hi All.
The diff is now on the bench and its a 3.6 , I know this has 108mm output flanges (I have the driveshafts with it and stub axles as well) are the input flanges all the same as I am replacing a 7" with push in driveshafts with this one, so not sure if I need another propshaft.
Alan
Iain Mac
Sep 30, 2015 09:39 PM
mark r
Sep 29, 2015 07:27 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
IainRS1700T
Sep 25, 2015 06:44 AM
