ecu
Old Nov 15, 2009 | 09:30 PM
rslewis1's Avatar
rslewis1
Default ecu
hi guys need a bit of help can you use a 4wd ecu in a 2wd and vise versa cheers
Old Nov 16, 2009 | 07:04 AM
oldford's Avatar
oldford
Using a 4wd ecu in a 2wd car: Yes, if you change the wires from the TPS and use a 4wd TPS. You cannot use closed loop unless you connect a Oxygen sensor.
The chip also needs to be setup for a 2wd car and the knock sensor must be taken out of the setup. Same applies to closed loop, it must be taken out or a sensor must be added.
Using a 2wd ecu on a 4wd is also possible, again you have to change the wires on the TPS and use a 2wd TPS. And again the chip must be mapped for a 4wd engine.
Old Nov 16, 2009 | 07:59 AM
t4 and greys's Avatar
t4 and greys
cosworth gimp
he means the two outer wires on the tps switch need to be swapped over first but
in simple terms yes you can
much easier using the search facility though as questions like this been answered in depth a bilion times
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
griffo69
Oct 4, 2015 11:58 AM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
DixieTheKid
Sep 14, 2015 09:04 PM
Tank Mike
Sep 14, 2015 03:56 PM
