zvh starter motor
Old Nov 15, 2009 | 12:14 PM
jimrs16i's Avatar
jimrs16i
Default zvh starter motor
i have got a 1.8 zetec bottom end to fit into my s1 engined rs1600i... its the one with the two piece ally and steel sump... i just need to know whats the best way to fit the starter i am going to use the turbo gearbox... it looks like the ally part of the sump might need cutting back.. help please .. cheers
Old Nov 15, 2009 | 06:00 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
either cut the sump back and get it welded or get a rear starter gearbox and change the internals for the rs one
Old Nov 15, 2009 | 06:15 PM
crazycage's Avatar
crazycage
just cut the webs off there is no need for any welding.
you cant really see it well but thats a blacktop sump.
Old Nov 15, 2009 | 07:08 PM
jimrs16i's Avatar
jimrs16i
cheers ... i thought it could be cut back but just wanted to check...
Old Nov 15, 2009 | 07:24 PM
DaveyBoyS1's Avatar
DaveyBoyS1
Are you sure you know what you are doing? Just cutting things off can be costly....
Old Nov 15, 2009 | 07:51 PM
jimrs16i's Avatar
jimrs16i
shut up dave you muppet.. you will be the one cutting it off while i am cutting a hole in the block for the water pump
bobsworth
77
Mar 24, 2016 09:30 PM
A.t.p
Oct 23, 2015 07:54 PM
cossie362
Oct 11, 2015 03:53 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
marky_g
Sep 12, 2015 04:26 PM
