Transferbox - what oil or fluid?
Old Nov 14, 2009 | 06:14 PM
dakunia's Avatar
dakunia
Default Transferbox - what oil or fluid?
Hello,
some people recomended to use in transferbox on MT 75 4x4 gearbox a ATF fluid, for better cooling viscous unit and to prevent throw out through trans box breather.
But some people recomended to use in transferbox the same oil like on gearbox.
I decide to use on gearbox an Mobil 1 SHC LS 75W-90, but what oil/fluid You recomended to use in transferbox?
I have freshly rebuild box, with Quaife big tooth gearset, new bearings, new transferbox chain and uprated viscous unit 60Nm.
many thanks for info
maciek
Old Nov 15, 2009 | 05:02 PM
dakunia's Avatar
dakunia
nobody know what have on Yours drivetrain?
Old Nov 16, 2009 | 08:17 AM
oilman's Avatar
oilman
What model and year do you have?
Guy
Old Nov 17, 2009 | 05:31 PM
dakunia's Avatar
dakunia
Escos BT '92. Gearbox rebuild and moded as described abowe...
Old Nov 18, 2009 | 08:43 AM
oilman's Avatar
oilman
Its recommend an ATF, You could try a high spec/racing one for better performance and tempt stability.
Guy
Old Nov 19, 2009 | 06:37 PM
dakunia's Avatar
dakunia
Smile
Guy
Thank You for recomendation.
Brickhouse
14
Oct 3, 2015 07:28 PM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
SMILER258
Sep 28, 2015 09:04 AM
