Mk2 Escort Rack
Old Nov 8, 2009 | 09:07 PM
nstrug's Avatar
nstrug
Default Mk2 Escort Rack
Hi -
Can anyone tell me where I can get new tie rods for a Mk2 Escort steering rack? I had a slight *ahem* incident that has left both tie rods bent. I really don't want to get a whole new rack as everything else if fine - just 2 new (or used) inner tie rods.
NB It's the inner tie rods (i.e. the bit that bolts into the rack) that I want - NOT the tie rod ends - they're fine.
Nick
Old Nov 9, 2009 | 04:38 PM
Same as a lot of other fords, the drumsticks just screw in the end of the rack, or you could always heat up and straighten yours.
Old Nov 9, 2009 | 04:45 PM
nstrug's Avatar
nstrug
Hi Tabetha -
I've got the rods out no problems (once I realised there was a rollpin locking the end caps on).
I'll look at straightening mine out then - would heat to cherry red and straighten in a vice do the trick?
I would still prefer new ones tbh, but it looks like they can't be bought separate from a rack.
Nick
Old Nov 10, 2009 | 04:28 PM
They can defo be bought seperate, but will be fine if straightened, yes heat till glowing then vice/hammer them till straight/ish, don't have to be 100%, as will be adjusted and maintain same length anyway.
Dr. Ickxs
Sep 15, 2015 10:15 PM
bassboy
Sep 10, 2015 08:54 PM
imnoteasy
Sep 7, 2015 09:26 PM
Ade
Alloy wheels and ICE for sale
Sep 7, 2015 05:06 PM
