bleeding brkes
Old Nov 5, 2009 | 12:34 PM
Smartdj.'s Avatar
Smartdj.
Default bleeding brkes
hi guys im going to change the disc all round on my mr2 as there rubish and have no feel to them and the brake fluid is basicaly black!! but do i need all four wheels off the ground to do this? stupid question i know,,i take it u cant do one side then the other?
Old Nov 5, 2009 | 02:15 PM
There's no reason you can't do one wheel off ground at a time.
Just make sure you get fresh fluid through to each caliper, if wanting better feel use braided lines, and you can also take off the anti rattle shims, I always do, but compound/make dependant could lead to noises, I use yellowstuff with anti rattle backing removed from rear of pads and never heard a sound in 3 years.
Some pads have a very dead feel to them, even if they work well, I found this with the DS range and so now use only ebc as all have feel which is how I like it.
As regards the order, I just do whichever one is easiest and never follow and order, and never have a problem, so long as enough run out to get new fluid at each wheel will be fine.
Old Nov 5, 2009 | 02:27 PM
TurboShed's Avatar
TurboShed
Cossiemodo
Why does the wheel need to be off the ground?
Old Nov 5, 2009 | 03:35 PM
Smartdj.'s Avatar
Smartdj.
thank you very much tabetha!
im sure iv herd u had to have all four wheels off the ground for some reason :S
Old Nov 5, 2009 | 06:36 PM
You heard wrong, in fact with some cars you MUST have the wheels fully loaded, ie car on the ground because of the type of load sensors they have, might stop decent flow of fluid through them.
Old Nov 6, 2009 | 06:24 PM
crazyshad1's Avatar
crazyshad1
as long as you can get to the bleed nipple you dont need to jack it up and take the wheel off. just make sure you keep topping the res up and get nice clean fluid through, as above really
Chas
Oct 5, 2015 07:13 PM
kevin36
Sep 9, 2015 11:12 AM
markk
Sep 9, 2015 08:11 AM
kevin36
Sep 8, 2015 12:23 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
