small turbo phase sensor voltage.
Old Nov 4, 2009 | 03:51 PM
Rabbit's Avatar
Rabbit
Default small turbo phase sensor voltage.
Bosch phase sensor originally mounted on escos eec-iv. How many volts does this need?
12v or 8v? This is a hall sensor so i guess 8v volts,.. but you newer know before you know you know
Searched forum and 12v is stated, but anyone running these on 8v?
Old Nov 5, 2009 | 03:32 PM
Originally this would have most likely been a 5 volt reference feed, 5V is fairly typical for ecu's sensors.
So long as powered and working it will produce the square waveform needed.
Old Nov 9, 2009 | 12:32 PM
sailorbob's Avatar
sailorbob
Do you mean the camshaft positioning sensor? If so, this has a 12v feed.
Old Nov 12, 2009 | 06:56 PM
Rabbit's Avatar
Rabbit
OK, my autronic SM4 provides 8 volts for the cam sensor (hall effect) and i wonder if its enough?
Old Nov 14, 2009 | 03:14 PM
The sensor doesn't "need" any particular amount of current, it is the disturbance of the electric field as the trigger passes it, this change is what acts as a on/off square wave signal, so long as it has whatever the ecu puts out, and the engine is turning over fast enough it will work.
manuel boeckx
13
Oct 3, 2015 02:29 PM
Anutternutter
Aug 21, 2015 06:07 PM
IAN RS2k
Aug 18, 2015 07:51 PM
muz
Aug 16, 2015 12:57 PM
Zoggon
Aug 10, 2015 10:39 AM
