Exhaust cam seized - What to do?
Old 31-10-2009, 08:29 PM
cosworth
cosworth's Avatar
Question Exhaust cam seized - What to do?
Hi,
Just had the #3 bearing seize on my Cosworth. Probably due to some debris in the oil clogging the oil line to the bearing.
Took the bearing retainer off and there was some damage to it. Metal from the head/bearing had melted onto the cam.
Since there is no bearing shells to change, what is the procedure to repair this? Is the head salvageable or do I need a new head (and camshaft obviously)?
Thanks for any help!
Old 01-11-2009, 12:23 PM
The shell can be salvaged by milling to take a shell bearing proper, on just that one bit, not often done, as not often a problem.
Failing that if you have some more caps check the tightness with a replacement cap, if ok can use that.
A lot of places inc ford garages mix and match the caps I have found, seemingly to no detriment, presumably they were all pretty close to start with.
Old 01-11-2009, 04:06 PM
cosworth
cosworth's Avatar
Thanks Tabetha, will look into that. I have a spare head (with other damage) so will check if the bearing cap #3 will fit (or rather if it still makes a "round hole" for the camshaft when used on the cyl. head that's on the car.).
01-11-2015 06:53 PM
XR4
Ford XR Range
01-10-2015 12:46 PM
Quick Reply: Exhaust cam seized - What to do?
