Hi newbi here idle problem
Old Oct 27, 2009 | 06:38 PM
leeboy_09's Avatar
leeboy_09
Default Hi newbi here idle problem
Hi all new to the site, ive got an idle problem with my escort 1.8 si (1997) only just got the car, it drives spot on but when idling it sometimes revs up and down and sometimes wont idle at all (you have to rev it to keep it running lol) and when u pull up to a junction and leave of the throttle and put the clutch in the revs drop and it cuts out un less you rev it, please i need help im of work tomorrow so can go and get the parts i need if any, does anyone know wahst up or have the same problem, seems like a good site by the way thanx lee
Old Oct 27, 2009 | 08:53 PM
martysmartie's Avatar
martysmartie
Does it do it once car has warmed up as well?
If it only does it from cold then ISCV isnt working, although you do say it hunts so shows idle valve is functioning intermitiently, I would replace the CTS (Coolant Temperature Sensor) if problem is only when engine is cold.
If still stalls when at running temp then your base idle needs seeing to.
Martin
Old Oct 28, 2009 | 07:03 AM
leeboy_09's Avatar
leeboy_09
Hi it does it after its been running for a whille as well thanx
Martin
Old Oct 28, 2009 | 01:15 PM
tarry500's Avatar
tarry500
Idle control valve?
Old Oct 28, 2009 | 01:39 PM
martysmartie
Then theresa base idle issue but unless someone has tampered with it there is no reason why it would have changed. I would make sure you have no air leaks anywhere.
It's not your ISCV as you have said the car "Hunts" this shows the ISCV to be working and it would not stop the car from running when hot as it's not used unless a heavy electrical load etc is applied. Normally if this fails the car will be harder to start from cold.
Martin
Old Oct 28, 2009 | 07:28 PM
leeboy_09's Avatar
leeboy_09
Thanx for the replys guys i cleaned the breather pipes induction and cold air flow pipes and the butterfly on the throttle body, but really strange this one if you strat the car and put your foot on the throttle and leave it on for 30 secs just above 1000 rpm the just ease off it runs and idles fine (strange) but if you start it and rev it hard and let the revs drop really quick it wont idle or will idle up and down and cut out at junctions
so could resetting the ecu work?
i bought the car two days ago and the previous owner has fitted a fse power boost valve induction kit and exhaust so maby this is part of the problem???? any other advice would be greatful thanx lee
Old Oct 28, 2009 | 07:35 PM
boothy's Avatar
boothy
Sounds like you have a sausage stuck in the inlet mate,take it off for a look
Old Oct 28, 2009 | 07:56 PM
leeboy_09's Avatar
leeboy_09
Hey Boothy do you think if i put it in a bun with brown sauce it would be ok to eat
Old Oct 28, 2009 | 10:38 PM
boothy's Avatar
boothy
Yeh man should be spot on
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
