more problems
Old Oct 24, 2009 | 05:05 PM
anfy's Avatar
anfy
Default more problems
hey i have had my rs turbo about 3 weeks and had a lot of problems but any way i went to start it this morning and it was running sh*it again had one of my mates round and he said it wasnt fueling and messed around with my fuel reg and it wont run now i checcked all my fuel lines and fuel pump i took the pipe off the fuel filter to see if fuel was cuming through and it was but only very slowly i removed the pip cuming stright from the fuel pump and its flying out would it be a problem with my filter or is there a bleed valve on the efi fuel rail could it be my regulator goosed does any one cocme from the middlesbrough area who knows any thing about this problem cause i dont mind paying
Old Oct 24, 2009 | 07:33 PM
It should come out the filter almost as quick as the pump itself, so try a new filter first.
Old Oct 25, 2009 | 07:44 PM
anfy's Avatar
anfy
hey cheers mate i changed the filter and it idles now but as soon as i go to give it any revs it cuts out so i stripped the regulator off any cranked it over and fuel is coming through the efi fuel rail could this be a problem with my regulator ??
Old Oct 25, 2009 | 08:42 PM
It's more likely to be running very lean, so I'd check that first.
Old Oct 25, 2009 | 08:56 PM
anfy's Avatar
anfy
well had the plugs out and they are sutted up dry blk and after few mins of ideling it cuts
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
