Focus st170 clutch change
Old Oct 22, 2009 | 11:58 AM
B16JUS's Avatar
B16JUS
Default Focus st170 clutch change
just thought id ask incase there is any special tool or technique needed.
ive said i will help a friend change his clutch on his st170 i say help he hasnt got a clue lol
im presuming its driveshafts off, bellhousing bolts, clutch cable, reverse sensor
is there any special tools needed ? or special technique
cheers
Old Oct 22, 2009 | 12:33 PM
cossieDavedree's Avatar
cossieDavedree
hydraulic release not cable, the flywheels are dual mass so hopefully theres not too much play in it. If flywheel fooked get a silvertop flywheel and clutch kit,
The cables for the gear change can stretch or bind so check they are free to move,
Otherwise a pretty normal job.
Old Oct 22, 2009 | 01:52 PM
B16JUS's Avatar
B16JUS
cool cheers for that
fingers crossed lol
Old Oct 29, 2009 | 07:33 PM
B16JUS's Avatar
B16JUS
sorry 1 more question im not sure on.
are the drive shafts like vw etc just unbolt or when removed they leak fluid everywhere ?
Old Oct 29, 2009 | 10:51 PM
cossieDavedree
u'll have to drain the gearbox oil first yep,
Old Oct 30, 2009 | 12:11 AM
Sp3no's Avatar
Sp3no
Did mine a few weeks ago, as mentioned the fly wheel and slave cylinder will need replacing also. There are approximately 13 bolts holding the gearbox to the engine.
Drain fluid
Shafts out
Remove rear gearbox mount
support engine
remove air filter box
remove battery and battery tray
remove coilpack
support gearbox
Remove gearbox mount
unclip gear selector cables
Remove clip and pull slave cylinder hydraulic line from box
unclip speed sensor and reverse light switch
loosen subframe bolts, 4 at back 2 up behind the suspension strut, lower and inch
wedge engine forward about 300mm with a bit of wood
remove the 13 gearbox bolts, all different lengths so draw a diagram for where they came from
Wiggle gearbox off.
Refit is reverse of removal.
Things to note, you need a breaker bar for some nuts, if your removing the shafts completely you will need a 32mm socket. Definately change the fly wheel it WILL die if not already. Dont forget NEW flywheel bolts DONT use old ones.
Patience, i did mine myself with no help, took all weekend. I would never have done it without 2 hydraulic trolley jacks AND a gearbox support bar.
Dont forget your tourqe wrench
You will have to bleed the brake system, with the clutch pedal after so dont forget brake fluid. Gearbox oil get from Ford 75w90 is the stuff you need. Bleeding the clutch can be a pain, you might need to reverse bleed the clutch and you may need to bleed the brake system also
Good luck its a twat of a job
Ford Focus ST Parts for Sale
Aug 28, 2015 01:32 PM
cameron2
Aug 25, 2015 07:18 AM
Palethorpe01
15
Aug 18, 2015 06:09 AM
gordyshreds
20
Aug 10, 2015 02:59 PM
