205 block
Old Oct 14, 2009 | 06:20 AM
1cosworth's Avatar
1cosworth
Default 205 block
can someone tell me if the standart cosworth pistons can fit str8 in the 205 block from a 2lt sierra or wot is involved to do that.thanks
Old Oct 14, 2009 | 07:24 PM
Straight direct fit, although obviously will seriously lower the cr.
Old Oct 15, 2009 | 06:32 AM
1cosworth's Avatar
1cosworth
Default 205 block
thanks tabetha but wot is the cr
Old Oct 15, 2009 | 07:31 AM
CR = compression ratio, this will be around 8 to 1 on a std cossie, if using a different than cossie head could be even lower depending on chamber volume in the head.
No good unless for turbo applications, as just too low, assuming it's for a non turbo car then use 2.8 V6 cologne pistons in +90" form for 2086 CC!!
Last set I bought were £38 for 4 pistons.
Old Oct 15, 2009 | 11:33 AM
1cosworth's Avatar
1cosworth
Default 205 block
thanks tabetha
gcfcos
59
Oct 6, 2015 05:04 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
AJC
Oct 1, 2015 06:47 PM
20/20 vision
Sep 29, 2015 11:27 AM
20/20 vision
Sep 28, 2015 03:03 PM
