rs turbo bleed valve
Old Dec 24, 2004 | 12:50 PM
s1rscustom's Avatar
s1rscustom
Default rs turbo bleed valve
just about tp fit 1 as had the car setup and was told fit one as amal valve is leaking, do still use the same 3 pipes as keep hearin can block one off, anh help be gratefull cheers
Old Dec 24, 2004 | 01:36 PM
GrimmeRS2K's Avatar
GrimmeRS2K
Put the bleed valve in between the turbo and actuator, the one wot comes from the metering unit i blocked off.
But ive changed my back to an amal valve, (got a new one from ford around £40 though), car boosts better and resists the temptation of turning the boost up and blowing it up!!, still kept the one one from the metering unit blocked up as it ran better like that.
Old Dec 24, 2004 | 01:58 PM
s1rscustom's Avatar
s1rscustom
yeah sorted it now matey thanks a lot i was told block it off too and think thats how old s2 was but ran metering one to the middle one and goes fine and idle's fine so think il leave it like that for now, its in car boost and set actuator so holds 18psi with bleed valve open and bout 10psi shut, thanks anyway matey,
Matt Baxter
Sep 16, 2015 08:30 PM
blackbeautyzetec
Aug 29, 2015 02:11 PM
Chopshop85
Aug 17, 2015 06:38 PM
jay030787
Aug 17, 2015 06:16 PM
Churtz
15
Aug 13, 2015 06:40 PM
