rebuilding t2 help
Old Dec 23, 2004 | 05:33 PM
turbomad1's Avatar
turbomad1
Default rebuilding t2 help
hi i have a t2 turbo the bearings are ok in it but the seels have gone i can get the seels for around 70ish but i was wondering how hard it is to change the seels
if anyone has done it please let me know
cheers keith
Old Dec 24, 2004 | 09:51 PM
turbomad1's Avatar
turbomad1
up
Old Dec 25, 2004 | 11:04 AM
markk's Avatar
markk
the whole kit will come with bearing seal rings and all associated clips 'o'rings and fastenings,
its very easy to do the kits, just remeber how it comes apart, this is very important as you will forget when youve got it all in bits, the seals as you call then , one on the back near teh exhaust wheel , there like a small piston ring , be careful when fitting as they will stretch, apply plenty of oil and gently press the shaft back into the core one you replaced the bearings which are held in by small circlips. iirc the front of teh T2 has a small plated front seal which is compressed on when the comp wheel is fitted , all very straight forward once youve done a few !!
good luck , all you need is a clean surface - is a must as any shit will fook the thrust in no time , lay everthing down in order !
enjoy !!
Old Dec 26, 2004 | 12:44 AM
turbomad1's Avatar
turbomad1
cheers mate nice one thanks for the advice keith
Old Jan 1, 2005 | 11:20 PM
turbomad1's Avatar
turbomad1
up
Old Jan 2, 2005 | 07:56 AM
2001ode's Avatar
2001ode
Hi,
Remember that point when dismantling :
Regards
Old Jan 2, 2005 | 10:07 AM
turbomad1's Avatar
turbomad1
thank you for the advise
cheers keith
Old Jan 2, 2005 | 10:24 PM
abdr500's Avatar
abdr500
be car full most t2 are left hand thread so you bascially have to tighten up to losen the nut on the shaft other wise if you go the normal way of losening a nut you will end up snaping the shaft so you must be tighting up to losen the nose nut
bobsworth
77
Mar 24, 2016 09:30 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Mc5506
Oct 5, 2015 09:57 PM
coscor86
Sep 20, 2015 01:21 PM
