Lowering Issue
Old Sep 25, 2009 | 10:50 PM
aarc's Avatar
aarc
Fiesta RST All The Way
Default Lowering Issue
got a bit of a problem my fiesta rs turbo has just come out of the garage after a full rebuild of engine and repaint, bot the arches are catching the wheels ive got 195/45r16 tyres on the cosworth alloys no idea about the springs as i bought it as it is i just need about 1" inch clearance on both sides, there are a few things i could attempt puttting a bigger coil assitor on the fronts, place like a rubber bushing at the top and bottom end of the spring any other mods please help
Old Sep 26, 2009 | 10:49 AM
Even 1" height clearance will not be any use, as with suspension compression will easily be over 1", unless springs are nearly solid.
I would just get some longer springs.
Mark_
14
Jan 16, 2016 05:27 PM
Nov 1, 2015 06:53 PM
Fudgey
21
Sep 30, 2015 06:19 PM
SMILER258
Sep 28, 2015 09:04 AM
IainRS1700T
Sep 25, 2015 06:44 AM
