2 bar boost... how do i get it?
Old Sep 25, 2009 | 07:48 PM
forevaford's Avatar
forevaford
Default 2 bar boost... how do i get it?
right guys my 2 wd saph is set up at 2 bar boost.
im currentl using a greddy boost controller to achieve this, but its all over the place and is doing my head in, iv got a -34 actuater on their wound out to as much as i dare and with no boost control it will holt about 1.2 bar!
my question is how can i get this boost without using a poxy boost controller?
air to air injectors? im running l8 ecu with pectel bored
thanks for any info
Old Sep 25, 2009 | 07:55 PM
Ebonycossie4x4's Avatar
Ebonycossie4x4
boost does not always mean power,
uprate the head gasket take all the ignition out and wind up boost.
Be slower and drive like a sack of shit but you will have 2Bar lol.
Old Sep 25, 2009 | 07:56 PM
Ebonycossie4x4
sorry what you ean is you have lost boost, Surely you need a new actuator?
or the turbo is in trouble.
Old Sep 25, 2009 | 11:07 PM
forevaford's Avatar
forevaford
sorry, wot i mean is i have really good spec, and was mapped at 2 bar. with a boost controller that has inconsistancy, so i want to bin it and go back to std amel valve and dash 34 actuater?? but wots the maximum boost achievable from this setup?? shurely not 2 bar??
Old Sep 26, 2009 | 10:45 AM
If the set up is capable of achieving 2 bar, then with a correct actuator and amal it will do 2 bar.
Old Sep 26, 2009 | 05:39 PM
forevaford's Avatar
forevaford
thats wot i wanted to here thank you, i hate boost controllers
will my -34 actuater be sufficient?
Old Sep 26, 2009 | 06:37 PM
So long as it's healthy yes, there is nothing wrong with the std amal valve, I run one despite my ecu being able to run air injectors if I want, well they aren't actually air injectors, they are CNG injectors, bosch don't make air injectors.
Old Sep 26, 2009 | 06:47 PM
fatmike's Avatar
fatmike
i have a gizmoboost controlerset at 2 bar of boost took me 20mins to fit and set up mate would advise 1 off them
Old Sep 27, 2009 | 04:46 PM
forevaford's Avatar
forevaford
thanks guys.
iv tried a couple of boost controllers now an at pressent im using a Greddy speck 2 or somthing, i keep blasting up and down the bypasses, stopping having an adjust then going again, boost is all over the place. just want my 2bar or near without big spikes or tail offs.
i have a feeling tho that my turbos running out of puff as its only a t38.63, i have rs500 intercooler with big ports and manifolds so.... iduno. i will try ditching the boost controller and using std amel valve setup, il try and let u guy no how i get on
cheers
Old Sep 27, 2009 | 06:59 PM
T38.63 will run 2 bar without any problem so long as healthy.
Old Sep 27, 2009 | 09:28 PM
fatmike's Avatar
fatmike
i adjusted mine while i was driving mate 2 buttons and thats it it hits 30psi bang on every time noboost spike and no trailing off have a look in to it mine is a gizzmo spec 2
Old Sep 28, 2009 | 12:24 PM
Raj_FRST's Avatar
Raj_FRST
Half Rice Half Chips
ive spoken to a few tuners regarding this as my amal valve was buggered, more than one person has recommended the blitz spec s boost controller
You may have tried this, just thought I would mention just in case you hav'nt
Nov 1, 2015 06:53 PM
155lee
Oct 24, 2015 11:11 AM
IainRS1700T
Sep 25, 2015 06:44 AM
Cos500
Sep 16, 2015 09:50 PM
Tony W
Sep 9, 2015 12:08 PM
