Cossie rep, few problems.
Old Sep 14, 2009 | 09:25 PM
nealo's Avatar
nealo
Focus WRC
Default Cossie rep, few problems.
ok guys, based on a 1.4 escort the problems are..
fuel gauge just seems to be at rock bottom even though i know there is fuel in the car, anybody know what this could poss be?
headlights were working fine but both went off at the same time, sidelights,full beam and all indicators work and i tried changing fuses but the headlights are still out - anybody have any ideas what this might be? (i know the headlights are brighter than standard 1.4 escort however i assume the wiring and fuses are the same)
the car has an RS turbo engine fitted, so not sure if this makes any difference on the above.. although i wouldnt think so?
any help muchos appreciated.
Old Sep 14, 2009 | 09:43 PM
focusjohn's Avatar
focusjohn
St.
Did the car come from anglesea area mate?
Old Sep 14, 2009 | 09:49 PM
nealo's Avatar
nealo
Focus WRC
no it came from Chorley.
Old Sep 14, 2009 | 09:59 PM
nealo's Avatar
nealo
Focus WRC
nobody?
Old Sep 14, 2009 | 10:38 PM
studabear's Avatar
studabear
check for power at headlight bulbs first, if both have no power it could well be the switch
fuel gauge is probably a fubared tank sender unit
Old Sep 14, 2009 | 10:43 PM
nealo's Avatar
nealo
Focus WRC
if they have no power to them could it be the relay on the switch?
also, how much is a tank sender unit?
i just want these few little problems sorting on it now.
also the engine temp gauge shoots straight up to red becase the fan is running to cool the engine from the get go, but the engine does run very nice and smooth boosts fine and doesnt spit any water etc.
Old Sep 15, 2009 | 08:15 PM
nealo's Avatar
nealo
Focus WRC
anybody else please?
Old Sep 15, 2009 | 08:17 PM
studabear's Avatar
studabear
put it into a garage or tuner if your not too sure about working on cars
Old Sep 15, 2009 | 08:23 PM
DeanRS's Avatar
DeanRS
COS-its-WORTH-it
the complete fuse boxes are prone to failure on all mk5 escorts mate, not sayin it is defo that but may be an option
Old Sep 15, 2009 | 08:28 PM
nealo's Avatar
nealo
Focus WRC
stud, its not that - i just not quite sure where to start.. iv checked all the fuses and replaced them and its not done anything.
i dont think its the fuse box as everything else is working besides headlights and the fuel gauge. Can relays blow?
Old Sep 15, 2009 | 08:38 PM
studabear's Avatar
studabear
you need to get a test light or power probe and start finding where you have and haven't got power too, if you can get to the wiring for the tank sender unit, I would imagine it has 2 wires, unplug the connecter then bridge the 2 wires, fuel gauge should go to full, if it does this confirms the tank sender is fubared
Old Sep 19, 2009 | 08:52 AM
nealo's Avatar
nealo
Focus WRC
All sorted now, headlights are fixed and working, fuel gauge is fixed and working to!
Going to now sort an exact reading for the engine temp.
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
IainRS1700T
Sep 25, 2015 06:44 AM
