engine mount problems
Old Sep 14, 2009 | 08:53 PM
cabriolet's Avatar
cabriolet
Default engine mount problems
am putting a turbo diesel engine into a mk4 cabriolet [ex efi cvh] the engine nount bolt holes from the cvh mount are spaced too far apart to bolt to the diesel engine does anyone know of a mount with the bolt holes closer together ie almost as close as u can hold your three fingers together any help would be appreciated [rumour had it fiesta 1'6 diesel had it] lad im doing it for not very happy been trying to sort this out for weeks
Old Sep 14, 2009 | 11:18 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
would it not be easier to change the mount for one off a diesel?
surley the bay will be the same between the two, can't see ford changing it.
Old Sep 20, 2009 | 10:04 AM
cabriolet's Avatar
cabriolet
diesel has solid mount will tear the mk4 chassis open been there seen it done it most diesel mounts have two studs sticking upwards off the mount only want one
Old Sep 20, 2009 | 10:29 AM
Can you not cut off the wrong part, make the right part and weld on to make the mount you want ?
Old Sep 20, 2009 | 07:42 PM
cabriolet's Avatar
cabriolet
looks like im going that way tab cant see another way round it thanks for opinions fellas
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
track.focus'd
Aug 12, 2015 05:53 PM
st220kyle
Ford Mondeo Including ST
Aug 6, 2015 09:17 PM
lockie
Jul 31, 2015 10:03 PM
