Cossie tick over fault
Old Dec 21, 2004 | 04:14 PM
G4V  RS's Avatar
G4V RS
Default Cossie tick over fault
I have a stage 2 G reg Sapphire, i ticks over high at abot 11-1200 rpm, i have cleaned the idle speed control valve & if i un plug it the engine cuts out so i dont think its the isc valve, i have turned the screw on the bottom of the throttle body (the one with a 14mm lock nut) but this doesnt alter the idle speed, what else could it be? also somimes the idle is aratic when i pull up at junctions surging up & down
please help
CheeRs Gav
Old Dec 21, 2004 | 04:20 PM
G4V  RS's Avatar
G4V RS
Alos forgot to mention that the car idles very high when started from cold, well over 1500rpm
cheeRS Gav
Old Dec 21, 2004 | 04:34 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
TPS, well that's what was wrong with mine.
Old Dec 27, 2004 | 10:01 PM
nicksaph's Avatar
nicksaph
hello mate
have you cleaned out the throttle body as well?
mine had a similar prob.
took the throttle body off and cleaned it out in thinners. put it back and reset the base idle and its been alright since.
might be worth a try.
are you the gav that knows matt messe?
cheers nick
Old Dec 28, 2004 | 08:20 AM
alan rainbow's Avatar
alan rainbow
you need to set the base idle and go from there then when you plug the iscv in if the idle changes then something is telling the ecu to lift the rpm could be tps or temp sensor hope this helps where in notts are you
Old Dec 28, 2004 | 09:29 AM
G4V  RS's Avatar
G4V RS
Cheers for all the advice everyone! nick, do you mean matt that works for merc? Alan im in Heanor
CheeRS Gav
Old Dec 28, 2004 | 09:45 AM
nicksaph's Avatar
nicksaph
yes mate.
he was the guy that give me your number about that s/s zorst you sold a couple of years back.
tankybaby66
Feb 6, 2016 02:24 PM
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
