Cosworth 4x4 power
Old Sep 12, 2009 | 09:47 PM
jayscos's Avatar
jayscos
Default Cosworth 4x4 power
HI CAN ANYONE HELP BOUGHT MY SIERRA COS 4X4 AS A STANDARD CAR I HAVE NOW FITTED MONGOOSE EXHAUST 803 GREENS 3 BAR ITG FILTER RADTEC FRONT MOUNT -31 Ahmed Bayjoo Stage 3 ECU Chip and Pectel Baby Board BUT DOES NOT SEEM ANY QUICKER AND THE REV LIMITER HAS NOW DROPPED TO ABOUT 6500 ALSO DOES ANYONE KNOW WHAT DIZZY CAP SHOULD BE FITTED ITS A 91 RED TOP BUT THE CAP THATS FITTED IS A STRAIGHT CAP BUT THE LEADS SEEM TO RUB THE INLET MANIFOLD
Old Sep 12, 2009 | 10:19 PM
creator's Avatar
creator
try getting it all set up mate
Old Sep 13, 2009 | 08:45 AM
It should feel massively different, especially torque wise.
I suspect there may be a problem with the car to start with before the conversion.
Usuall things to look at are the voltage at the fuel pump under load, how old is the fuel filter ?
If it has not had one a fuel pump rewire is going to help resist meltdowns, and is a must, as well as the fan rewire.
Old Sep 13, 2009 | 12:08 PM
KSA-Cossie's Avatar
KSA-Cossie
I'd get it serviced and set up m8.
Old Sep 13, 2009 | 12:35 PM
col cos1's Avatar
col cos1
il bet your actuator is set at 8psi
do you have a boost gauge?
Old Sep 13, 2009 | 07:32 PM
LHD220Turbo's Avatar
LHD220Turbo
did you pre load the actuator rod?
or have you even adjusted it?
Old Sep 13, 2009 | 09:01 PM
jayscos's Avatar
jayscos
Hi thanks for the replys i have adjusted the actuator nearly fully in could it be that it needs to be remaped?
mk3 fiesta cosworth
Aug 23, 2015 10:31 AM
Anutternutter
Aug 21, 2015 06:07 PM
charliecosworth
Aug 19, 2015 02:00 PM
cossie4x4
Aug 14, 2015 06:29 PM
Aug 14, 2015 07:29 AM
