RS500 i/c into esccos
Old Dec 21, 2004 | 12:34 PM
Kelv's Avatar
Kelv
Almost there!
Default RS500 i/c into esccos
Currently got a Pace RS500 style i/c cooler in the car along with a pace 65mm alloy rad.
im changing the intercooler over to a genuine RS500 i/c and just wondered if anyone else has got a genuine one in the escorts and if they had any problems fitting it?
Also is the thickness of a genuine i/c thicker than the pace item, havent picked up the genuine one yet to compare.
Just wondereing if ive got enough space for both as its already tighter than an extremely tight thing in there already, and will i have to down size my radiator?
Ta!
Old Dec 21, 2004 | 02:57 PM
kjc300's Avatar
kjc300
You will have to mod the gen cooler turbo side spout to point outwards, otherwise the boost pipe will foul the alternator!!!
On the other hand you could just buy mine - which is already done!!
I'll also throw in the special hoses I had to get for it too!!
All fits on a treat with no problems!!!
Old Dec 21, 2004 | 03:01 PM
kjc300's Avatar
kjc300
The width of the core on the genuine cooler is about 45mm!! Just measured it!!
Old Dec 21, 2004 | 03:06 PM
wayneclayden's Avatar
wayneclayden
590 BHP/Ton
kelcos,
The pace and genuine are virtually the same thickness(40mm core and 52ish on the end tanks)
If you have space probs you could fit a slim line fan kit like this one
kind regards
wayne
Old Dec 21, 2004 | 03:29 PM
Kelv's Avatar
Kelv
Almost there!
Hmmmmm, i like that.
Best get it all in place 1st and see what i can get away with!
Old Dec 21, 2004 | 04:19 PM
THE RADMAN's Avatar
THE RADMAN
what you fitting on yours now kev?
Old Dec 21, 2004 | 04:39 PM
kjc300's Avatar
kjc300
The Obvious mate!! bought the rad, pre-cooler and header tank at national day!!
Ridgey
12
Nov 2, 2015 06:54 PM
Nov 1, 2015 06:53 PM
stephenb4506
33
Oct 2, 2015 06:25 PM
IainRS1700T
Sep 25, 2015 06:44 AM
coscor86
Sep 20, 2015 01:21 PM
