ignition system with Haltech E8 ecu for YB
Old Sep 3, 2009 | 08:46 PM
ital_cossie's Avatar
ital_cossie
Default ignition system with Haltech E8 ecu for YB
hello,
i bought from US a haltech E8 ecu to fit to my sierra cosworth 4wd, i would like to know if it will work fine with my coil pack conversion (motorsport development) or i will need to buy an other ignition system, for example MSD dis2.
wait to read your opinion
Old Sep 4, 2009 | 11:09 AM
ital_cossie
there's nobody who has installed haltech ecu on his cossie??
Old Sep 5, 2009 | 04:52 PM
I assume there must be something on the Haltech site regarding this ?
Most ecu's, certainly aftermarket will run coilpack though.
Old Sep 5, 2009 | 05:03 PM
The E8 and E11 do indeed run coilpack, but will need externals amps, 2 in the case of a 4 cylinder coilpack, as it will output on ignition 1 and 2 drivers to drive cyls 1+4 2+3, the ecu does not have internal amps for this.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
griffo69
Oct 4, 2015 11:58 AM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
