Cosworth Exhaust valves
Where is the cheapest place to buy a full set of inlet and Exhaust valves for a cosworth, Exhaust valves need to be Sodium filled.
I've seen the cheap ones on Ebay but i'm sure the Exhaust valves are not Sodium filled.
Thanks
Thanks
Prices from www.grahamgoode.com
GGR333 Sodium Filled Exhaust Valve Cosworth £37.50 each
GGR332 Inlet Valve Cosworth £24.95 each
Anyone know somewhere cheaper
Thanks Tabetha £10 is more like it.
I was lucky before and got a full set of new valves, valve guides, hydraulic lifters and valve seals for £200 on ebay.
But just had a timing belt tensioner slip on me with the extra vibrations after fitting up rated engine mounts to the car and bent every valve.
XE ones are smaller than cosworth ones so it seems unlikely they were them, so Im not sure what vauxhall it would have been, I would be interested to hear what he said.
Getting cheaper
www.burtonpower.co.uk
inlet valves £19.95
Exhaust valve Sodium filled £29.00
Still looking but need to buy ASAP
PJ Motosport 01902 862 882
inlet valves £14.50
Exhaust valve Sodium filled £31.50
inlet valves £19.95
inlet valves £14.50
Stainless steel exhaust valves are good for use in engines producing upto 350 bhp, thereafter sodium filled should be used. Some tuners have run engines over 350bhp succesfully with stainless steel exhaust valves. stainless are circa £16 each, whereas sodium filled are about £29 with the vat.
