Help to id front sturt sierra
Old Jul 21, 2009 | 07:48 PM
Mull XR's Avatar
Mull XR
Default Help to id front sturt sierra
Alright people i had a 91 sierra twin cam. I was making a bit of a drifting machine. I brought some spax front suspension. They never fitted into the hubs. They were too fat. Think there from 4wd sierra. So need help to id what i have here.
Dimensions
Base diameter (where it goes into the hub) 4.5cm
From the base to the spring cup 24cm
From the base to the very top of the top mount 57 cm
So if anyone can help that would be great
Old Jul 22, 2009 | 11:45 PM
Mull XR's Avatar
Mull XR
Any ideas?
Old Jul 28, 2009 | 07:10 PM
Mull XR's Avatar
Mull XR
can anyone help as these are sitting here doin nothing.
Old Jul 28, 2009 | 07:27 PM
robrs2's Avatar
robrs2
2wd thin tube at the base. 4x4 thick tube at the base
Old Jul 29, 2009 | 06:03 AM
The two basic types are either 2wd or 4wd, you have the 4wd, then there is a different height spring pan, on the lower ones as fitted to cossies etc you can just about get your little finger between the tyre and spring pan(with 205/50X15), other spring pans you can get two fingers in there easy.
Old Jul 30, 2009 | 10:17 AM
Mull XR's Avatar
Mull XR
I thought i had the 4wd ones. I also know about the cosworth front as thats what i brought frist time. Had to get 205 gti alloys to get the wheel away from the spring.
Roosie
11
Aug 22, 2015 10:13 PM
C2 MAK
Aug 20, 2015 09:46 PM
Vincereese
Aug 15, 2015 06:24 PM
Vincereese
Aug 11, 2015 08:44 AM
Old ford
Jul 31, 2015 06:50 AM
