P8's
Old Jul 17, 2009 | 11:03 AM
hughy's Avatar
hughy
Default P8's
hi, does the p8's control the amount of fuel thats needed on there own unlike the L8's you have to adjust them manualy with the screw? cheers hugh
Old Jul 17, 2009 | 01:23 PM
grcossie's Avatar
grcossie
P8 have not any co adjust screw, it depends how the chip is made, some doesn`t use lambda sensor signal, other does, and in combination whit other sensors, it control fuel amount
Old Jul 17, 2009 | 01:36 PM
Stu @ M Developments's Avatar
PassionFords Creator
Correct, P8 is under closed loop control using feedback from the lambda sensor to adjust fuel content itself. As are the late L8s of course.
Old Jul 17, 2009 | 01:39 PM
andy130's Avatar
andy130
what would be best to use if your going for a good 380bhp P8/L8?
Old Jul 17, 2009 | 01:42 PM
Both are perfectly capable of that conversion so best to just ask your calibration supplier which he has the best programs for.
Old Jul 17, 2009 | 09:29 PM
costina's Avatar
costina
Live long and prosper!!
The guy above does a cracking 380 bhp P8 map using 55lb siemens
Paul
