XR3i cabby wont start
Old Jul 16, 2009 | 10:01 AM
shaggy85's Avatar
shaggy85
Default XR3i cabby wont start
i have a 1985 escort cabby xr3i and am having some trouble with her! she starts fine 1st thing on a morning when the engine is cold but once it has been running for a while if i turn engine off i can start it back up within 30 seconds but say i pull over and go into a shop, when i come to start it again it seems to turn over forever then fires into life i think it maybe somthing to do with the warm start regulator but i really dont know. any ideas will be most welcome, thanks in advance
Old Jul 24, 2009 | 09:29 AM
shaggy85's Avatar
shaggy85
bump, really need some help
Old Jul 26, 2009 | 01:23 PM
XRSTI's Avatar
XRSTI
COULD BE LEAKY INJECTORS
had same prob with mine swapped them and it sorted the problem
in sayin that i swapped all the other bits to before i did pain in the arse
Old Jul 27, 2009 | 04:48 PM
xrmalin's Avatar
xrmalin
Id try and recreate the problem on your driveway run it up to temperature switch it off wait a couple of minutes like you would be going into a shop then just unplug the warm up regulator if it fires straight up theres your problem
mark
Old Jul 28, 2009 | 11:45 AM
shaggy85's Avatar
shaggy85
cheers guys will try the things you said and let you know!
Old Aug 5, 2009 | 07:22 AM
shaggy85's Avatar
shaggy85
rite guys an gals, sorry in the delay in posting back. in regards to xrmalin's post to recreate the problem on the drive i did this and un plugged the warm start valve and still nothing happened (took ages to fire up again) once running i let it warm up again and this time i i unplugged the cold start valve and it fired on 1st turn of the key!! so obviously this is my problem but what i dont get is why, could it be the car thinking the engine is still cold so its flooding it hence not firing up, as also ive noticed it starting to smoke out the exhaust and liquid dripping out the tailpipe
comments/help welcome as always
Old Aug 7, 2009 | 10:20 AM
shaggy85's Avatar
shaggy85
does anyone know where i can get a cold start valve from in yorkshire area or know someone who has one for sale
thanks
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
xrmalin
Sep 13, 2015 06:52 PM
andrewmctiernan
Sep 8, 2015 03:05 PM
stevierob
Sep 7, 2015 07:09 PM
bigryrs
Sep 7, 2015 06:45 PM
