JIC/metric/imperial threads!!!
Old Jul 14, 2009 | 10:24 PM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
Default JIC/metric/imperial threads!!!
Does anyone have a simple guide to which kind of threads is used in what in fords???
Ive got tons or aeroquip on my car and i want to buy some more to do fuel pump, filter etc and to replace some of the jubilee clips with finishers else where on car.
From what i understand it, aeroquip hose system is built around the JIC standard for threads, and you have to buy adaptors to fit metric or imperial threads with hoses.
If so does any one have a list of the common threads used in fluid systems on fords?? ie what threads are for the banjo on fuel pumps, filters etc etc etc
Old Jul 14, 2009 | 10:34 PM
Luca's Avatar
Luca
Lukesville
This start to help you
http://cgi.ebay.co.uk/AN-6-Cosworth-...lenotsupported
Old Jul 15, 2009 | 12:13 AM
Psycho Warren
Carbon Crazy
ahh cool
Only one problem, i cant see possibly how they expect thier adaptor for the outlet to fit!!!
its totally wrong adaptor.
Old Sep 24, 2009 | 09:09 AM
vinnya77's Avatar
vinnya77
Originally Posted by warrenpenalver
ahh cool
I have the same problem. How did you make this fit please? Also building a fuel system using aeroquip.
Old Sep 24, 2009 | 09:21 AM
Touring Car Spares's Avatar
Touring Car Spares
Unscrew all of it , fit the Aeroquip fitting , fit the pipe to that ,simples .
Old Sep 24, 2009 | 09:41 AM
vinnya77's Avatar
vinnya77
Thanks, I've seen a few pics of cars though which look like they have a silver adaptor of some sorts. What is the piece to be unscrewd then? It looks like a valve I think. If it is removed what size fitting is required for it?
Old Sep 24, 2009 | 04:00 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
/\ it's a one way valve for a banjo fitting, just remove it, just means the pump must prime to get pressure up befor eit starts, if no prime it'll just take a bit longer to fire up due to the pressure not being there from the off.
Old Sep 24, 2009 | 06:54 PM
vinnya77's Avatar
vinnya77
Thanks, I think I'll stick with the Banjo then, will just be a little more awkward not coming straight out the back.
Old Sep 24, 2009 | 09:20 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
i got a fitting from a local hydraulics place, i lost the one way valve, but no big issue really.
just takes a second for pressure to rise.
gcfcos
59
Oct 6, 2015 05:04 PM
DavidK
Sep 27, 2015 02:55 PM
