External wastegate plumbing
Old Jul 13, 2009 | 08:40 AM
Shonky's Avatar
Shonky
V6 Ka of Love
Default External wastegate plumbing
How do I plumb in the boost controller to the wastegate? There are two nipples on the one I have, do I blank the side one and put the controller in the top one?!
Usually you get a vacuum from the plenum but due to where the turbo is located I'd rather not, can I simply take a feed from the air pipe between the filter and the turbo?
I haven't got the nipples with the external wastegate, they're 10mm with a really fine thread, can I get them anywhere or shall I try a hydraulic/hose place?
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
pabloXR
Sep 21, 2015 12:42 PM
coscor86
Sep 20, 2015 01:21 PM
