tyre pressures
Old Jul 12, 2009 | 11:01 AM
muffster's Avatar
muffster
Default tyre pressures
morning.
Does anyone know what tyre pressure i need to put in my sapphire cosworth? Its got standard wheels and 205/50/15 tyres.
Thanks.
Muffster.
Old Jul 12, 2009 | 11:09 AM
ickey818's Avatar
ickey818
According to the Ford owners manual tyre pressures are as follows:-
Tyre size 205/50 VR15
Normal load - up to 3 persons. Front 30psi Rear 33psi
Full load - over 3 persons. Front 33psi Rear 37psi
Old Jul 12, 2009 | 11:20 AM
Rax's Avatar
Rax
I dont think you would go far wrong with 32 all round,every car I have had has always had 32psi.
Old Jul 12, 2009 | 11:33 AM
muffster's Avatar
muffster
thanks for the replys.
Those figures sound familiar. Not done it for ages as it was in a garage for 6 years!
So should the rear be more than the front?
I thought it would be the other way round.
Thanks,
Muffster.
Old Jul 12, 2009 | 03:43 PM
Driven wheels normally more on 2wd(front or rear).
I would have a play with pressures, when on Uniroyal Rainsports I used 33F 35R, when on F1 GSD3(awful btw) I used 35F 35R, now on Vredestein Sportrac 3's it is 33F 34R that work best, I always experiment till I get the best.
Different tyres will work better at different pressures even at same size, as some have soft sidewalls some hard etc plus other differences.
Old Jul 13, 2009 | 03:27 PM
kosienutter's Avatar
kosienutter
Last Time, Get Off PF FFS
i pump 34psi in all my tyres on mi 4x4. got toyo t1r proxes.
Old Jul 14, 2009 | 09:11 PM
opposite lock's Avatar
opposite lock
I,ve got a print out sheet off Graham Goode site few yrs ago, tyre pressures as follows
205/50/15 normal load and speed F31psi R34psi
'' heavy load normal speed F34psi R37psi
'' normal load high speed F34psi R37psi
'' heavy load high speed F38psi R44psi
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
Alloy wheels and ICE for sale
Sep 28, 2015 06:19 PM
