Reverse Switch
Old Jul 11, 2009 | 08:18 PM
djsri's Avatar
djsri
Default Reverse Switch
After searching i still cant find my answer so sorry for another reverse light question!
I have no reverse lights on my s2 escort turbo. I've brought a new switch (located just to the right of the started motor looking from the front?).
Wiring seems good, when i bridge the plug reverse lights come on. New switch so its not that, so could something inside the box be broken causing the switch not to make contact?
Many thaks for any info.
Old Jul 12, 2009 | 08:56 AM
If it's a new switch that works fine(have you tested this) ?, then assuming it's fitted correctly there is only one thing left, ie it's not being operated by the detent on the gearbox, but I've never heard of this.
Even though new can still be faulty so operate it by hand, by either pushing or releasing as appropriate.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
rsguy
44
Sep 29, 2015 03:29 PM
cossie330
Sep 27, 2015 04:13 PM
cameron2
Sep 20, 2015 04:30 PM
The Enigma
Sep 12, 2015 10:12 PM
