Fitting oil temp sender
Old Jul 11, 2009 | 08:02 PM
mcfeat2005's Avatar
mcfeat2005
Unhappy Fitting oil temp sender
Got a 3 door sierra cosworth. Can`t put the adapter plate on the oil filter as the filter will hit the engine mount, is there any other way to fit the oil temp sender. Cheers allan
Old Jul 11, 2009 | 08:23 PM
mattjones_81's Avatar
mattjones_81
you can buy sump plugs with a threaded insert and fit sender in through that. Thats what's on my 2wd saff
Old Jul 12, 2009 | 08:53 AM
Just get a fitting in the oil pressure hole with room for one more fitting.
Old Jul 12, 2009 | 10:36 AM
JTECH James's Avatar
JTECH James
Passion for Fords!
thats the best place imo
Old Jul 12, 2009 | 10:49 PM
rs2klee's Avatar
rs2klee
K***LMT
yup got that aswell, but just to take note if your thread on the sump is a bit worn, the adapters only have about 5 threads to screw into the sump, lucky my sump thread was ok but still used some ptfe tape on the adapter thread just to keep it nice and leak free
Old Jul 13, 2009 | 12:26 PM
mcfeat2005's Avatar
mcfeat2005
Thumbs up
thanks guys just ordered a sump plug. thanks for everyones reply`s
Old Jul 16, 2009 | 10:50 AM
Heitmann's Avatar
Heitmann
Bear in mind that if the temp sender is not long enough it will not show correct temperature - the temp sender needs to be well into the sump.
Old Jul 16, 2009 | 10:56 AM
lead_foot's Avatar
lead_foot
is awesome
Why not get a sandwich plate between the block and the oil filter?
Old Jul 17, 2009 | 05:55 PM
kosienutter's Avatar
kosienutter
Last Time, Get Off PF FFS
i have a type of adaptor that tabetha is on about. i can post it to you. totally free. pm me, if interested.
or as lead foot said, a sandwich plate this is what you need. this though has a pressure sender fitted too.
Old Jul 17, 2009 | 09:23 PM
I fancy one of these for my saff.
Old Jul 17, 2009 | 10:24 PM
kosienutter
bought it of a mate who was breaking his.
manuel boeckx
13
Oct 3, 2015 02:29 PM
Kop2381
Aug 23, 2015 01:17 AM
mrmann
Aug 20, 2015 11:24 PM
marky_g
Aug 19, 2015 11:46 AM
COSWORLD
Aug 14, 2015 07:40 AM
