Suspension fabrication and help
Old Jul 6, 2009 | 10:06 PM
volcomstone411's Avatar
volcomstone411
Default Suspension fabrication and help
Yea, basically i want to change the suspension on my FRP
Nobody supplies off the shelf suspension for the frp basically because tickford to gain the wider track, took a standard hub and bored it larger and too a larger angle. Eibach then made a shock absorber to fit. This means that it is larger than any others.
I already have adjsutable lower arms and rose joints.
However, i want to get some kind of coilover.
I was thinking, but need advice, could i not use an eccentric top mount to bring the top mounts out to make the added track and use standard, non angled hubs with normal coilovers?
picture to aid explanation:
Old Jul 7, 2009 | 11:44 AM
I would certainly start with std hubs, then do as you say with top mount etc.
Old Jul 7, 2009 | 08:24 PM
volcomstone411
any other ideas maybe?
Old Jul 7, 2009 | 08:30 PM
ScORTED's Avatar
ScORTED
Project Money Pit
GAZ... they normally do custom fitted coilovers for about £500, or they used to, just need to take your car to them, I'd be on the blower to them :thumb:
Old Jul 7, 2009 | 08:37 PM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
jacko on projectpuma is sending a set of FRP dampers off to a coilover company to get a cost of custom coilovers estimated.
Old Jul 7, 2009 | 10:39 PM
chameleon's Avatar
chameleon
what about leda,think they do custom struts and have been doing suspension for fords for years,would be my 1st choice.
Nov 1, 2015 06:53 PM
SMILER258
Sep 28, 2015 09:04 AM
