escos engine tech question
Old Jul 4, 2009 | 04:32 PM
R5COS's Avatar
R5COS
Default escos engine tech question
Hi all, my mate is just finishing the bottom end build of my engine, and 1 of the ARP big end bolts wont clear the oil pick up pipe its fouling it, but when the old ford big end bolt is used it will clear it, has anyone ever come accross this problem before and what should we do ? the head is slightly longer on the ARP bolt but surely this shouldnt be happening
what are my choices just use 2 old big end bolts as if i use just 1 old wouldnt that be a weak link so to speak ??
my car is a BT escos 200block 4x4 oil pump pick up pipe etc
any advice please chaps need this engine built today
Old Jul 4, 2009 | 05:12 PM
Looks like a CAREFUL re-bend of the pipe is needed.
Old Jul 4, 2009 | 05:25 PM
R5COS's Avatar
R5COS
moved it a tiny tiny bit with the bolts loosened by using a screwdriver then retightened the bolts looks to be problem solved, thanks Tabs
Old Jul 5, 2009 | 08:28 AM
No probs matey.
bigryrs
Mar 28, 2016 09:11 PM
bigryrs
Fiesta RS1800/RS Turbo
14
Jan 21, 2016 09:54 PM
james kiely
Aug 28, 2015 08:58 PM
c20tbo
Aug 17, 2015 10:19 PM
Bailes1992
Aug 16, 2015 07:14 PM
