mk5 escort eletrical problems
Old Jun 28, 2009 | 08:19 PM
mark m's Avatar
mark m
Default mk5 escort eletrical problems
right after some advice have a few issues with a mk5 escort 1.6 cabby
when the 15a fuse for the interior lights and clock is left tin the red light on the dash stays on
when the injetion is switch on it remains on dim
the interior fan fails to work the fan works and the fuse is on
and the waser pump dont work again ok any ideas>?
Old Jun 28, 2009 | 08:47 PM
costina's Avatar
costina
Live long and prosper!!
sorry to say but the mk5 has issues with the fuse box its a common fault with them
could be something as simple as a coupler not fully cliped in remove them 1 at a time and refit
worth a try
Paul
Old Jun 29, 2009 | 08:04 PM
mark m's Avatar
mark m
any ideas if the boxs can be repaired or replacment only any ideas wher i can get a diagram for the fuse box?
Old Jun 29, 2009 | 08:52 PM
costina's Avatar
costina
they have a double layer curcuit board inside which are held together via loads of solder tag connections if the problem is not visable on the outer then its a no go imo m8
pop it out and remove the fuse cover first then the main cover you might be lucky and find your problem
remember take pics as you go for all relay positions and bridging links
replacement is costly depending on what box u have
Paul
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
sridgett
15
Aug 3, 2015 07:26 PM
