cossie stem seals
Old Jun 26, 2009 | 09:30 PM
costina's Avatar
costina
Live long and prosper!!
Default cossie stem seals
Am i right in thinking you cannot do cossie stem seals with the head on as the springs are set too deep?
Paul
Old Jun 27, 2009 | 05:13 AM
No can be done so long as you can compress the valve springs, using the nylon rope trick.
Old Jun 27, 2009 | 04:08 PM
costina's Avatar
costina
explain please chris nylon rope ??? u got me interested now
Paul
Old Jun 27, 2009 | 04:18 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
tbh, its hardly worth the agro imo,
id be much much happier flipping its lid, and re cutting the valve seats, checking guide play etc at the same time
its only about an hours work to get the head off a yb
Old Jun 27, 2009 | 10:57 PM
costina's Avatar
costina
I got it down to 20 mins just wanted the know
Old Jun 28, 2009 | 11:38 AM
WongRS's Avatar
WongRS
mine need doing too i think, but the heads only just gone back on after a rebuild (i bought dodgy stem seals, retard!) handy to know it can be done without removing the head.
Old Jun 28, 2009 | 05:48 PM
Just feed nylon rope into the combustion chamber through plug hole, then turn engine so the piston compresses the rope holding the valve in place, so the only cost is rope and seals instead of new gaskets, a freeze etc.
Old Jun 28, 2009 | 07:27 PM
costina's Avatar
costina
Ta next question is how to compress the spring?? i can see how the rope is better that compressed air
Paul
Old Jun 29, 2009 | 06:31 AM
That's the big question, I usually knock something up if needing to do something along these lines on a 1 off basis, but never done cossie in situ.
Cosnada
Jan 7, 2016 05:30 PM
Nov 1, 2015 06:53 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
muzzman1
Sep 30, 2015 08:59 PM
