EFI Conversion
Old Jun 23, 2009 | 12:18 PM
GooseRST's Avatar
GooseRST
Default EFI Conversion
For a S2 ERST running MFI how much does it cost to convert to EFI, where does it... and most of all whats the advantages and is it really worth it?
Old Jun 23, 2009 | 12:25 PM
ollie240585's Avatar
ollie240585
Depends what route you want to go down,
fiesta turbo set up?
Aftermarket ECU set up, omex, emerald, megasquirt, etc?
Cosworth ecu/loom?
Old Jun 23, 2009 | 12:34 PM
GooseRST's Avatar
GooseRST
I have no idea mate..
I'm a virgin to all this lark?
Can i have a few comparisons? pros and cons..
Old Jun 23, 2009 | 05:57 PM
ollie240585
I'm not familiar with the cossy set up, so cant really comment on that.
The fiesta set up is probably the easiest and cheapest. Will require an inlet manifold and coil pack from a fiesta, throttle cable and a few sensors dotted round the engine bay, that all pretty much bolts on, the inlet manifold will need either an adaptor plate or an EFI head fitted. Major problem is the crank sensor, this will either require the block to be drilled out and a sensor fitted, or burtons do a crank sensor kit which bolts on to the altenrator side of the crank shaft. I think its about £120 or so. This will allow you ti run the rs turbo engine on EFI, ditching the metering unit, the distributor, the coil, losing most of the loom. Fiesta EFI has the advantage of improved reliability and slightly better fuel economy. Downside is that it costs more money to set one of these up. With an rs turbo you can do a few mods, adjust the fuelling slightly, and the jobs a gooden. Fiesta EFI requires chips and different stages to get the most out of modifications.
I am going down the other route, the more expensive route!! I've picked up Omex 600 ECU and loom for £610, getting the loom made up and the car mapped is costing me a further £350. On top of this I have had to buy the above fiesta bits, manifold, coil pack, throttle cable, map sensor etc. I have cheated a little and am using a ZVH engine. As the Zetec engine has the crank position sensor, this allows me to run efi on this with no further modifications. The advantage of omex will be getting the extra potential out of the engine. The fuelling and timing will be specific to my engine and I believe it is the best way of doing things!!
The above is my opinions and may be subject to argument.
Old Jun 23, 2009 | 06:02 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
mfi is king for easy power, chip zorst, -31, set up and ya away, fiesta EFI needs chipping, injectors, ect,
mfi is good when it works, but its old technology, if u have a new metering head and all working sensers, all works well.,
cossie is popular and works well, as are megasquirt, gotec ect ect
all have pros and cons,
Old Jun 23, 2009 | 06:34 PM
ollie240585
I agree to a certain extent, if running less than 200 BHP MFI is a good management system, not the most efficient but does work adequately.
If you want to go EFI, for that higher tuning potential and that extra reliability then i'd say that going on a stand alone mappable ECU is the best way to do it!!
Old Jun 23, 2009 | 08:19 PM
Phil2002's Avatar
Phil2002
Check out www.rsbible.co.uk for the fiesta route. i have an efi turbo block(needs big ends knocks a bit) and an efi head going cheap if needed!
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
SMILER258
Sep 28, 2015 09:04 AM
mpilk
Sep 27, 2015 09:21 AM
