Sierra Brake question....
Old Jun 22, 2009 | 11:37 PM
cossie04's Avatar
cossie04
Default Sierra Brake question....
Just a quick one, does anyone know if 4x4 cosworth front brakes fit onto a normal xr4x4 hubs please? I`m assuming they do, about to buy a set but just want to make sure before i buy them....
Cheers, Ed.
Old Jun 23, 2009 | 06:36 PM
They do but the height is very different, 4x4 is 53mm height, 260mm dia, 4wd cos is 278mm dia but 36mm height.
Old Jun 23, 2009 | 07:02 PM
cossie04's Avatar
cossie04
Cheers m8, might sound a bit thick but, what do you mean by height?
Old Jun 23, 2009 | 07:38 PM
mick's Avatar
mick
offset........ the disc doesn't sit in the middle of the caliper.............
Old Jun 23, 2009 | 09:21 PM
cossie04's Avatar
cossie04
Thankyou mick, this can be solved with spacers can they not?
Old Jun 24, 2009 | 06:30 AM
There may be another disc that is a lot closer to what you need.
What mix of bits are you trying to do, even discs from another make can be fitted, eg Lotus Elise 2001 discs are a exact fit for 288mm upgrade for vauxhall astra using veccy calipers all bolt on.
There is a quite a good mix and match selection for fords as well.
Old Jun 24, 2009 | 12:30 PM
mick's Avatar
mick
it can but not something i have tried........... i had 283 rwd discs with granny cos calipers and was very effective, but others have tried and it may require a little fettling of the caliper...........
scorpio cosworth discs are 4 stud, the right size 278 and the offset is closer, not sure with the 4x4cos calipers though,
tbh i haven't noticed any real difference with a car with 4x4 cos brakes than a granny cos setup.................... saves pennies as well........
Old Jun 24, 2009 | 12:35 PM
snoopaloopa's Avatar
snoopaloopa
They fit straight on with 17mm spacers or you can use mondeo st discs and use 6mm spacers.
Old Jun 25, 2009 | 05:44 PM
Saaamon's Avatar
Saaamon
Edd, i'm pretty sure you use the 4x4 caliper and 2wd disc's.
Old Jun 25, 2009 | 08:22 PM
mick's Avatar
mick
the 4wd calipers are for a 278 disc the same as a granny one.................. now with a granny one i fitted 283's but others have had to alter the caliper to allow the disc to actually turn..
Old Jun 25, 2009 | 10:12 PM
andrewg's Avatar
andrewg
fitted loads with two spacers between caliper and hud
yatta
May 21, 2016 10:31 PM
155lee
Oct 27, 2015 04:55 AM
focus2351
Sep 9, 2015 09:33 PM
cossirob
Sep 3, 2015 09:17 PM
