noisey tensioner on esc cos
Old Dec 11, 2004 | 08:52 PM
ajjames's Avatar
ajjames
Default noisey tensioner on esc cos
my alternator tensioner on my 1995 esc cos wont stop squeeking i have changed the belt changed the tensioner for a good second hand one then bought two new beerings and they all get noisey within 5 minutes of running i have run out of ideas now and need help as i am getting some very strange looks when sat in traffic as it is so loud i have taken the air-cn belt off and that makes no differents to the noise and i have bought a snap on stephoscope which i have put on the alternator/waterpump and the power steering pump and they all run quite so the noise is deffinatly comming from this pulley any ideas much appriesiated as i have run out of ideas now cheers
Old Dec 11, 2004 | 10:05 PM
velocity's Avatar
velocity
may be a long shot.it may not be you tensioner at all,squirt a bit of wd40 directly on to the multy v part of the alternator belt while the engine is running see if clears,had a similar problem and swore it was everything else, turned to be the belt
Old Dec 13, 2004 | 05:36 PM
Dave Henshall's Avatar
Dave Henshall
the alternator on an escos is the actual tensioner, is uses a spring loaded self ajusting arm to set the tension. as above, have you swapped the acyual belt as they do go shiny on the multi'v's with age.
Old Dec 13, 2004 | 07:42 PM
ajjames's Avatar
ajjames
write thanks for the replies i have put some stuff called belt dressing on the belt and it does make it go quite briethly but then comes strate back the same so i am going to try another new belt from fords this time and see if that cures it i will post the results
Dave_b
Ford Focus (All Models)
Oct 13, 2015 05:48 PM
`spotty
Sep 25, 2015 11:41 PM
dombanks
Sep 21, 2015 08:38 PM
coscor86
Sep 20, 2015 01:21 PM
BigD.
Alloy wheels and ICE for sale
Sep 16, 2015 03:08 PM
