incredable offer
Old Jun 18, 2009 | 02:14 PM
Smiffy2k8's Avatar
Smiffy2k8
Default incredable offer
I have came along an offer on a 2lt pinto'd sierra for cheap. Will the pinto fit into a mk3 fiesta relativly easy i.e will work be needed on drive shafts, radiator, fuel, gearbox etc... if any one has a link to a write up on this or any body with info helps is much appriciated.
Heres info on the car
Its a 2.0 Pinto with the 205 Block, It has twin40's, A 4 branch with full exhast system.
A Piper Racing cam has been fitted and the inlets have been ported. The head gasket and timing belt where done when the cam was fitted and has only done two drift days since.
The standard viscous fan has been replaced with an bigger electric one. The steering rack has been changed to give better lock.
It has a welded Diff
tankybaby66
Feb 6, 2016 02:24 PM
gambo08
Feb 4, 2016 10:49 PM
Nick 172 Sport
Sep 28, 2015 07:21 PM
