flywheel refacing question
Old Jun 17, 2009 | 01:02 PM
Yura's Avatar
Yura
Default flywheel refacing question
Hello.
YB. I want to reface flywheel before put new clutch kit.
Tell me please how to remove guides(for clutch cover) from flywheel? And how to put it back? Or no need to remove it for refacing?
Old Jun 17, 2009 | 02:00 PM
svony's Avatar
svony
A pair of pliers should do the trick, may take a bit of effort tho...no special tool really needed. To reinstall make sure the holes on the flywheel are clean and guides are also clean then carefully tap them back in place.
Old Jun 17, 2009 | 02:41 PM
Yura's Avatar
Yura
thanks!
Svony, which clutch kit are you using on your cossie?
Old Jun 17, 2009 | 04:20 PM
Escos2483's Avatar
Escos2483
From: guernsey,c.i.. a rip off island , full of drunks
just a word of warning ... dont put them in a vice and try and twist them out .. they will snap off and you will have to drill out ... the ones i had were very tight in the holes ... the machine shop does it ,,, by putting the dowel in the vice and with a soft headed hammer hitting the flywheel and pulling them out that way .. i have yet to try that method myself ....
Old Jun 17, 2009 | 05:15 PM
Toe Knee's Avatar
Toe Knee
Just had mine done, 1 was snapped anyway so tried to drill it out and it drilled really easily as their just soft metal so snapped the heads off the other 2 and drilled them out as well!! I found a set of new dowls on ebay very cheap so replaced it with those rather than trying to re-use the old ones!
Old Jun 17, 2009 | 10:09 PM
costina's Avatar
costina
Live long and prosper!!
The company i use makes me new ones once they faced the fly
Paul
Old Jun 18, 2009 | 08:30 AM
Yura's Avatar
Yura
Thanks, will try your methods one by one!
I put flywheel in a vice then get grips on the dowels, then tap with a dead blow hammer, come out real easy that way but takes a few mins, rarely have to do this as just leave it to machine shop mostly.
Old Jun 18, 2009 | 10:39 PM
Toe Knee's Avatar
Toe Knee
Yea most machine shops will do it for u but the place i took mine would have charged more for removing them then making new ones to fit so was cheaper for me to just do it myself!! PLus it gave me something to do
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Mark_
14
Jan 16, 2016 05:27 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
stevecfrst1
Sep 30, 2015 05:18 AM
