mk4 escort efi fuel fueling problem...
Old Jun 10, 2009 | 07:16 PM
Toe Knee's Avatar
Toe Knee
Default mk4 escort efi fuel fueling problem...
Right basically converted a mk4 mfi to efi, left the original tank in with the mfi external
pump as didnt see it being a problem and the car ran fine for ages then all of a sudden it started to hold back/jolt, miss fire and even had problems starting etc so thought it could be a blocked filter and changed it and it ran fine after that, but then a while after same problem again, so changed it again and was fine for about a week and now its starting to play up again. Any ideas as to why?! obvvious thing it looks like is filter is clogging restricting the flow but surely not that quick?! First thought is shit in the tank or pump\regulator problem?!
But one thing i need to eliminate too is, on the mfi setup theres a cylinder thing the fuel pipe from the tank goes into then goes to the filter, do the efi escorts have that too or should i remove that?! Got a pic of it so you can see, had a similar thing happen in a 2i of mine but that turned out to be the fuel pump damper which had split on the in tank pump which obviously this doesnt have, moy other thought is the mfi pump actually ok to use?! thought it would be due to it being a higher flow so shouldnt get fuel starvation unless obviously the pumps on its way out!
Old Jun 12, 2009 | 07:28 PM
B19 LBP's Avatar
B19 LBP
RS in the blood
hello m8
i dont know about the rst of your problem but i can tell you that on the EFI escorts they dont that thing in the picture, just the filter.
hope this helps you
Old Jun 12, 2009 | 08:17 PM
Toe Knee's Avatar
Toe Knee
Lovely cheers mate will take it off then!! Just wanted to be sure, if the efi's didnt come with it then best to take it off and see what happens, might be lucky and its just that but then this car really doesnt like me much
The system i got off u is spot on btw mate has a nice sound to it
Old Jun 12, 2009 | 08:20 PM
B19 LBP's Avatar
B19 LBP
RS in the blood
glad to help m8 and glad its going good m8,
out of interest who done your EFI conv, as im doing one on my cab and im stuck on the wiring??
Old Jun 12, 2009 | 10:11 PM
Toe Knee's Avatar
Toe Knee
I did mate, took a while to get the fooker workin as someone had cut alot of wires including the main earth for the ecu that goes to the battery (took me ages to realise that )
I managed 2 get hold of a whole loom out of an efi cabby that was at a scrappy and ripped out all the mfi loom and swapped them over!!
only bits i kept from the mfi setup as i said was the pump/tank etc, whats the prob with urs mate?!
Old Jun 12, 2009 | 11:06 PM
nickscunny's Avatar
nickscunny
That little cylinder thing is called a FUEL ACCUMULATOR...
Which basically maintains fuel pressure in your fuel lines.
Old Jun 13, 2009 | 06:53 AM
B19 LBP's Avatar
B19 LBP
RS in the blood
oh thats not good m8 but glad you got it sorted
ive got a EFI cabby that ive put and fiesta turbo engine to, ive also got a OFAB engine loom and OFAB ecu but cant work out how to fit the loom in,
be told to not use the loom and use the cars loom and just change pins but then again been told to fit the other loom
its the only thing im stuck on now
Old Jun 13, 2009 | 08:47 AM
Toe Knee's Avatar
Toe Knee
been lookin into that aswell and as far as i know if its got the efi loom in it then you dont need the fiesta loom. From memory you need to change the connector for the map sensor to work and have the right ecu and it should work, theres a load of stuff on this site on what u need if converting it like i did, and it says the OFAC ecu is easier to use but think it explains what u need to do to run OFAB.....
http://www.rsbible.co.uk/
Cheers nick, im guessing it was only really needed for the mfi escorts then if the efi ones didnt come with it?!
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
EoinXR3
Sep 7, 2015 05:44 AM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
