series 2 rs not boosting
Old Jun 3, 2009 | 07:12 PM
matty325's Avatar
matty325
Default series 2 rs not boosting
hi peeps can anyone shed any light on this strange problem ive got ,i took the head of my rs turbo to fit a stage 2 head and cam built it back up. its starting and running ok but im not getting any boost pressure when i rev the car the boost gauge goes up to the zero but no further the actuator is connected and so is the pipe from the turbo to the actuator, has anyone come across this ,any help would be great .could i have something on the wrong way? it was boosting fine before removal and you could hear the d/valve even when you revved it on the spot ,cheers in advance
Old Jun 3, 2009 | 07:19 PM
liam-rst's Avatar
liam-rst
shit happens
[quote=matty325;4188840]hi peeps can anyone shed any light on this strange problem ive got ,i took the head of my rs turbo to fit a stage 2 head and cam built it back up. its starting and running ok but im not getting any boost pressure when i rev the car the boost gauge goes up to the zero but no further the actuator is connected and so is the pipe from the turbo to the actuator, has anyone come across this ,any help would be great .could i have something on the wrong way? it was boosting fine before removal and you could hear the d/valve even when you revved it on the spot ,cheers in advance [/quotcheck the plug for the amal valve is plugged in i had this with my cab if not check all hoses for air leaks
Old Jun 3, 2009 | 08:04 PM
Barry R's Avatar
Barry R
You wont have boost pressure stationary
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
AJC
Oct 8, 2015 11:09 AM
Kiran1600E
11
Oct 2, 2015 11:35 AM
Russ Payne
Sep 25, 2015 08:29 PM
