Niggling electric window fault
Old May 29, 2009 | 12:28 PM
gordyshreds's Avatar
gordyshreds
Default Niggling electric window fault
not a ford, jag xj6 1993. thought id ask here as normally helpfull
None of the electric windows work, the fuse for the left hand side is fine
the fuse for the right hand side blows every time it is replaced, as soon as put in.
it's summer and hot, please help!!! Nothing looks obviously wrong
Old May 29, 2009 | 12:59 PM
cozmeister's Avatar
cozmeister
More boost Igor!
If ithe fuse keeps blowing then one of the feeds to the window circuit is being shorted to earth. Might be a switch or relay at fault, or the feed cable for the motor has maybe had its insulation rubbed through, causing a short.
Old May 29, 2009 | 03:30 PM
As said you have a dead short, so need looking at, could even be buggered motor, but hopefully something simple.
chowfornow
14
Jan 5, 2019 09:01 PM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
stevecfrst1
Sep 30, 2015 05:18 AM
cossie330
Sep 27, 2015 04:13 PM
