Big Turbo Cosworth Escort weak spark
Old 25-05-2009 | 09:02 PM
cossieford's Avatar
cossieford
Default Big Turbo Cosworth Escort weak spark
Car has 4000km. Cannot get enough of a spark to start. The ground is good. Changed coils twice. Changed ignition module. Changed crank sensor. Distributor and leads are new. Volts at coil are good. Timing checked. Anyone have any ideas?? I am at a loss with this one.
Here is a follow up. Went through everything again top to bottom. It looks like the gap in the plugs was off - plugs were new and the car had run 600km with them.
Last edited by cossieford; 28-05-2009 at 05:59 PM. Reason: problem solved-possibly help others
14-08-2015 07:29 AM
Blown Hell
05-08-2015 07:22 AM
adriansaleem
01-08-2015 09:28 PM
ginger1979
31-07-2015 09:56 PM
Escortdriver1
31-07-2015 02:36 PM
Quick Reply: Big Turbo Cosworth Escort weak spark
