Oversized pistons - 91.775
Old May 24, 2009 | 07:32 PM
kaisersolsay's Avatar
kaisersolsay
Default Oversized pistons - 91.775
Hi,
My 205 block needs a rebore due to bore wash and my mate has a set of 91.775 oversized pistons that he has run for literally 4000 miles. My queston is, what size are standard pistons and what cc will fitting these oversized take it to?
Anyone help?
CheeRS!
Old May 24, 2009 | 07:51 PM
louie1's Avatar
louie1
Default piston size
hi there you standard bore size is 90.82, if you rebore your block to 91.775 you are going to 1mm oversize and the block will be on its last legs, you need a .5mm oversize really. hope this helps you
Old May 24, 2009 | 07:57 PM
kaisersolsay
Ah ok. Will go for the 1mm as I dont plan on doing many miles on the Mk1 Cortina its going in. Thanks!
Nov 1, 2015 06:53 PM
little bram
Oct 4, 2015 12:13 AM
deathrider666
Sep 28, 2015 06:12 PM
dombanks
Sep 21, 2015 08:38 PM
ajamesc
Sep 8, 2015 06:51 PM
